Series 2 rods
Posted: Wed Jan 09, 2013 10:23 pm
by sydduckett
The control rods for series 2,s seem to come in two lengths, 320mm &310mm. Are the longer ones for italian/Spanish and the 310 for indian or the other way round or completley wrong.....
tga.
Re: Series 2 rods
Posted: Mon Jan 14, 2013 11:30 pm
by sydduckett
anyone have any info, ill only buy the wrong ones.....again
ta
Re: Series 2 rods
Posted: Mon Jan 14, 2013 11:39 pm
by soullad
Syd, without wading thru the drifts to the worko, I'd go for the longer sort, as you may be confusing the two lengths, as the shorter rods could be the S3 versions
Re: Series 2 rods
Posted: Mon Jan 14, 2013 11:54 pm
by sydduckett
soullad wrote:Syd, without wading thru the drifts to the worko, I'd go for the longer sort, as you may be confusing the two lengths, as the shorter rods could be the S3 versions
No thats fine, bit inclement out there at the mo. I thought the same but this has thrown me
http://www.allstyles-scooters.com/acata ... tings.html
what do you think?
sef
Re: Series 2 rods
Posted: Tue Jan 15, 2013 8:48 am
by Donnie
I'm going to assume you don't have the old ones to measure
It does seem odd, I thought that S1/2 rods were all the same personally but then when you get into remade stuff it can introduce too many variables.
Easiest thing Id think is simply ring allstyles and ask them to be honest.
Re: Series 2 rods
Posted: Tue Jan 15, 2013 2:59 pm
by sydduckett
Donnie wrote:I'm going to assume you don't have the old ones to measure
Yeah you may be right. Thing is I really wanted to get the headset internals of the series 2 spot on as sloppy gearchanges are a bug bear of mine. Have an SX headset on other scoot with wrongs rods that have to be drilled and it does my head in...
