Page 1 of 4
help bike wont start
Posted: Thu Jan 03, 2013 3:22 pm
by soulboy
its a t5 tried new plug massive spark but wont even cough never mind fire up .. even tried a little fuel down barrol but nothing any help would be great cheers
Re: help bike wont start
Posted: Thu Jan 03, 2013 3:29 pm
by Boothy_the_makem
Have you blocked air intake under seat with wet proofs etc ?
Posted: Thu Jan 03, 2013 3:47 pm
by soulboy
im runnin it without the air bellow have done for ages
Posted: Thu Jan 03, 2013 3:56 pm
by Boothy_the_makem
Hav ya checked air filter ?
Fuel feed to carb and cleaned jets ?
Posted: Thu Jan 03, 2013 4:06 pm
by soulboy
completly cleaned carb and filter realy pissin me off now ...could it be electricol :wtf: :flaming: am i right in thinking that if petrol is poured down barral the it should fire at least cause ive down that and got nothing ..i took the new plug out and it was bone dry ..sending me round the fukin twist
Posted: Thu Jan 03, 2013 4:14 pm
by Boothy_the_makem
Have you adjusted the brass screw at the side of the carb ?
Posted: Thu Jan 03, 2013 4:18 pm
by soulboy
if you mean the air/mixture screw ive set it at 1 and 3 quarters turns out everything was spot on before xmas when i put it away ..i started it 1st it was fine then it missed all over the place farted and stopped i just thought it was the plug
Posted: Thu Jan 03, 2013 4:24 pm
by goldeneye
woodruff key sheared?
Posted: Thu Jan 03, 2013 4:28 pm
by soulboy
had the fly wheel off all is nice and clean and as it should be
Posted: Thu Jan 03, 2013 4:30 pm
by Boothy_the_makem
goldeneye wrote:woodruff key sheared?
Could it be the flywheel oil seal dya reckon ?
