Rear brake cable
Posted: Sun Apr 26, 2009 11:16 am
by chunky monkey
Has anyone tried these are they any good
Re: Rear brake cable
Posted: Sun Apr 26, 2009 12:19 pm
by storkfoot
Yep, I have them on both my scoots and I'll never go back to the original bend the cable kerfuffle. These ones are so much easier to adjust. Only thing I'd recommend is to change the nyloc nut every know and then, maybe once a year, as they lose their "gripping" powers after they've been adjusted a few times.
Posted: Sun Apr 26, 2009 12:44 pm
by lammydave
storkfoot wrote:Yep, I have them on both my scoots and I'll never go back to the original bend the cable kerfuffle. These ones are so much easier to adjust. Only thing I'd recommend is to change the nyloc nut every know and then, maybe once a year, as they lose their "gripping" powers after they've been adjusted a few times.
agreed... fit one, you won't be dissapointed
Posted: Sun Apr 26, 2009 1:16 pm
by bristolmod
they are very good. Re the nylok, I slip the original brass adjuster on as well.
Recommended
Posted: Sun Apr 26, 2009 1:50 pm
by Bilko
Definately worth it.
Posted: Sun Apr 26, 2009 1:54 pm
by chunky monkey
Excellent im off to buy 1, thanks for the feedback
Posted: Sun Apr 26, 2009 11:53 pm
by Knowledge
PM me if you want one. I reckon I've sold 500, and never had one returned.
The best thing about them is the way it speeds-up the process of dropping then engine: take the nut off, and pull the inner and outer straight out the back of the crankcase.
Martin
Posted: Mon Apr 27, 2009 12:16 pm
by gaz_powell
BIT LATE - BUT I`VE GOT THEM ON ALL MY 3 BIKES - EXCELLENT
Posted: Mon Apr 27, 2009 5:20 pm
by corrado
As Tony the Tiger would say....." They're greaaaaaaaaat".
Posted: Thu Apr 30, 2009 4:31 pm
by Andy Pickering
Ive just fitted one :bouncyeng: :bouncyeng: :bouncing: :bouncing: :smug:
God a back brake that is fully adjustable and actually works
Cheers martin no problems easy to fit and adjust
