Series 2 steering lock
LI150
Main scooter: Series 2 LI150
Im sure Im being thick but how do you remove the lock :?
WINTERMODEL150
Take the top headset off ,inside you'll see a slotted screw above the lock,take the screw out,remove the alloy disc that's pressed into the casting,remove the plunger and spring then gently pull the lock out,if its tight then ease it out with a screwdriver .
Dean
LI150
Cheers Dean
