Series 2 steering lock
Posted: Sun Dec 30, 2012 9:38 pm
by LI150
Im sure Im being thick but how do you remove the lock :?
Re: Series 2 steering lock
Posted: Sun Dec 30, 2012 10:00 pm
by WINTERMODEL150
Take the top headset off ,inside you'll see a slotted screw above the lock,take the screw out,remove the alloy disc that's pressed into the casting,remove the plunger and spring then gently pull the lock out,if its tight then ease it out with a screwdriver .
Dean
Posted: Tue Jan 01, 2013 9:14 am
by LI150
Cheers Dean
