Page 1 of 3
ld body work on li frame
Posted: Mon Dec 24, 2012 1:55 pm
by RICSPEED
any one on here done it ?? i belive theres a bit of a problem regarding rear shock
Re: ld body work on li frame
Posted: Mon Dec 24, 2012 2:20 pm
by RICSPEED
seen this one york last year ..
Posted: Mon Dec 24, 2012 8:39 pm
by goldeneye
very cool scooter. a personal favourite was the "Model G "...a hybrid series 3/model D with 200 motor. looks just like an old open frame lambretta you would just walk past. still knocking about, anyone know who owns it now?
Posted: Mon Dec 24, 2012 9:01 pm
by RICSPEED
are you talking about the one ld ralph did ??
(rip)
Posted: Mon Dec 24, 2012 9:06 pm
by gerryjunior
I have one in the shed , i cut the ld arch off and welded it to a gp bar , shock has about 1" from top to frame , im using gp forks and ld mudguard. the panels fit fine but im missing ld legshields , i have the handle bars and horn cover, horncover wont match to gp legshields, saddles are too high im 6 ft and barely touch the floor , ill fit an ancillotti , ill have to make a bridge piece,, ill post up a pic for you ,
The one above looks like an ld with a series 3 bar welded to the ld bar , joined just before the engine mounts under the panels ,not just bodywork if you know what i mean and series 3 forks fitted,, mind you i could be wrong..
Posted: Mon Dec 24, 2012 10:07 pm
by goldeneye
RICSPEED wrote:are you talking about the one ld ralph did ??
(rip)
he might have done it Ric, it was /is the standard D green. last time i saw it, it had a long range series 3 tank and a sterling exhaust fitted, which sort of detracted from the "stealthiness" of it.
Posted: Mon Dec 24, 2012 10:45 pm
by RICSPEED
ok ..was going on the assumption that ld leggies and horn cast would fit (save for maybe shortening headstock) given that this scoot is series 1/2 with ld front end
though i can see from the pic the down tube profile does not match the leggies exactly .. also apology's for using this pic as it was someones on here
Posted: Mon Dec 24, 2012 11:14 pm
by gerryjunior
Ive offered the ld horncasting up to series 2 and sx legshields and it has a gap of about an inch in the centre , dont have ld legshields to try on the gp frame, there was a post on here a while back where someone fitted ld panelwork to a series 3 frame. ts1 engine i think, cant remember who though ,
Posted: Tue Dec 25, 2012 12:15 am
by carlos fandango
I have an ld that i was going to do this to (or fit an RS125 engine) and i was under the impression that the legshields fitted with a little modification to the height.
The rear suspension just needs to be angled down slightly, i think :oops:
I WILL get round to doing mine ...................one day :roll:
Posted: Tue Dec 25, 2012 12:57 pm
by RICSPEED
gerryjunior wrote:there was a post on here a while back where someone fitted ld panelwork to a series 3 frame. ts1 engine i think, cant remember who though ,
there was indeed .. silver one if i recall .. cant find the post though :(
