gran turismo mods
thebassmasta
Main scooter: GP TS1 240
Bought my lad his first scoot recently GT125, bit of a fixer up but will be a good scoot for his first ride.
The thing will want painting so while its apart we would have a look at the cosmetics'
I noticed they changed the rear light / number plate set up on later models, it sits a little higher than the early model.
I wondered if you could fit the later model rear light unit and number plate mounting to the early model i think it looks so much nicer
i think by the looks you would have to relace the lower side panel plastics and rear bumper section,
Any help appreciated :?
e type
Yes you are correct they do fit but u may need to drill a hole or get the bracket for the frame for the new tail light as the bottom of the light an later or 250/300 lights has 1 mounting lug compared to the early 125 2 lugs ..and yes all the rear plastics need changed to to complete the look if that makes sense
thebassmasta
thanks m8
