Page 1 of 2
Rear Hub Studs on Tubeless Rims
Posted: Wed Dec 19, 2012 11:18 pm
by Lamaddict
I'm looking at the SIP ones and AF ones, both look OK but do I have to change the rear hub studs with any of them? It's Servetta hub.
Re: Rear Hub Studs on Tubeless Rims
Posted: Wed Dec 19, 2012 11:23 pm
by cezeta
they need to be longer dont they? mbd make a set too.
Posted: Wed Dec 19, 2012 11:54 pm
by Lamaddict
cezeta wrote:they need to be longer dont they? mbd make a set too.
I've heard something like that but before I get the hub powder coated I might want to take the studs out etc and need to know if i need longer ones.
Posted: Wed Dec 19, 2012 11:58 pm
by clyde
Was told the Af ones fit fine and the SIP need work?
Posted: Thu Dec 20, 2012 12:54 am
by corrado
SIP ones fit fine too, but they come with longer studs which you'll need to change on your hub.
SIP made the centre section of the rim much thicker so that they could make the well deeper in order to get tyres on and off easier but that meant that they had to make longer studs to offset the thickness of the rim centre.
Swings and roundabouts really.
Posted: Thu Dec 20, 2012 3:28 pm
by soulsurfer
You'll need to file a little off the stud lugs for the Spanish hubs to take SIP rims, I'm not sure about AF rims. Better to try the wheel rim on your hub before coating ;-)
Posted: Thu Dec 20, 2012 8:14 pm
by nelson pk
soulsurfer wrote:You'll need to file a little off the stud lugs for the Spanish hubs to take SIP rims, I'm not sure about AF rims. Better to try the wheel rim on your hub before coating ;-)
I had to do this for my SIL hub as well.
Posted: Thu Dec 20, 2012 9:07 pm
by Lamaddict
This is worth knowing thanks but having to get the file out again to make parts fit is still annoying.
Posted: Thu Dec 20, 2012 9:46 pm
by soulsurfer
Maybe, but there's a really good reason that requires this, but its worthwhile IMO ;-)
Posted: Fri Dec 21, 2012 1:29 am
by corrado
It's the norm for parts not to fit after powder coating, especially parts that have fine tolerances to start with. If it's a snug fit before powder coating then it probably wont fit after powder coating.
