Page 1 of 2
Anyone stroke a RB20 kit?
Posted: Tue Dec 18, 2012 11:03 pm
by ulyssescale
Looking for some insight into stroking an RB20 kit with a BGM 60x110 crank. Any considerations to be made beforehand? I've never built a stroked a engine and interested in giving it a try. My next call will be to AF Rayspeed (since I bought the kit from them).
Thanks.
Re: Anyone stroke a RB20 kit?
Posted: Tue Dec 18, 2012 11:29 pm
by carlos fandango
ulyssescale wrote:Looking for some insight into stroking an RB20 kit with a BGM 60x110 crank. Any considerations to be made beforehand? I've never built a stroked a engine and interested in giving it a try. My next call will be to AF Rayspeed (since I bought the kit from them).
Thanks.
Well you wont be able to use that crank, unless your changing the piston ? the RB 20 uses a 116mm rod.
You could use a 60/115 crank, and you wouldnt need a packer, be sure to check the rings dont catch on the "fingers" of the boost ports at btc as they are pretty close normally .
Ive used a 58/115 crank and machined 1mm off the bottom of the barrel, after a three big end faliures with the 116mm rods
Russ
Posted: Tue Dec 18, 2012 11:34 pm
by drunkmunkey6969
You'll need a 116 rod, not a 110.
Im wanting to try a 62/116 stroke on an RB20 if any customers out there want one doing?
Main things to be aware of are deck height at TDC, over extended port timings, , piston skirt toughing casings at BDC, and if bottom ring drops below boost port legs at BDC.....you'll have to measure port timings and play with gaskets and packer plates until you get what you want. It can be tricky, but crack on and get stuck in!! ;o))
Posted: Wed Dec 19, 2012 10:29 pm
by ulyssescale
I'll just use the BGM crank for my Jet and use the AF 58x116 crank that came with the RB20 kit.
Thanks.
Posted: Wed Dec 19, 2012 10:34 pm
by Toddy
ulyssescale wrote:I'll just use the BGM crank for my Jet and use the AF 58x116 crank that came with the RB20 kit.
Thanks.
Does the AF crank have a welded pin now?
Posted: Wed Dec 19, 2012 10:41 pm
by ulyssescale
Toddy wrote:ulyssescale wrote:I'll just use the BGM crank for my Jet and use the AF 58x116 crank that came with the RB20 kit.
Thanks.
Doesn't look like it.
Posted: Wed Dec 19, 2012 11:58 pm
by carlos fandango
ulyssescale wrote:Toddy wrote:ulyssescale wrote:I'll just use the BGM crank for my Jet and use the AF 58x116 crank that came with the RB20 kit.
Thanks.
another Chubby Checker ill wager
Posted: Thu Dec 20, 2012 12:35 am
by ulyssescale
It's already been checked for true. I don't expect it to twist.
Posted: Thu Dec 20, 2012 12:41 am
by Muttley McLadd
I'd get an adult to check the pin isn't a thou' too small then.
Posted: Thu Dec 20, 2012 12:43 am
by ulyssescale
Can someone point me to a history/reports of this problem? This is the first I've heard of it.
