How Many Holes in S2 Sidepanels.
Gazbo72
Main scooter: SX200
I have just stripped my series 2 LI side panels and was wondering how many holes there should be for the panel badges ( scooter didn't have any badges when purchased).
Also does the remade panel badges have pins a per original or threads and hwld on with nuts ???
Rergads Gaz.
Gazbo72
Main scooter: SX200
Here is some pics
The bottom pic seems to have more of the smaller holes. If there is extra holes would fiiler cover them or will they need welding up ?
Thanks for any help a bit of a novice when comes to body work, Saying that I'm not much better with engines :lol:
carlos fandango
You should have 6 hole on your photos its the larger holes. 2 at the front one above the other, then moving towards the back low one then the new two slightly higher then the last lower again.
I would get the badges before you fill or paint the panels though . im not sure how the remade ones fit bot the original ones were peened over.
Russ
carlos fandango
Sorry im talking about side panels not legshields .
Gazbo72
Main scooter: SX200
carlos fandango wrote:Sorry im talking about side panels not legshields .
Sorry Carlos I put legshiels in the title by mistake. Now changed.
