imola woes
Posted: Mon Dec 10, 2012 7:02 pm
by tonytoolbox
hi all i have an imola (well not any more :cry: ) it drop a ring and now have about 1.5-2.0mm score running up from transfer port to top of barrel. my question is can this be rebored depending if i can get a piston to suit, or re linned what would you do, all anwers welcome (door stop perhapps :lol: ) thought ill get that one in first.cheers tony
Re: imola woes
Posted: Mon Dec 10, 2012 9:53 pm
by Ketje
Reboring and replating could be very expensive. Might be worth comparing the price with a new kit...
Mike.
Re: imola woes
Posted: Mon Dec 10, 2012 9:58 pm
by Muttley McLadd
tonytoolbox wrote:hi all i have an imola (well not any more :cry: ) it drop a ring and now have about 1.5-2.0mm score running up from transfer port to top of barrel. my question is can this be rebored depending if i can get a piston to suit, or re linned what would you do, all anwers welcome (door stop perhapps :lol: ) thought ill get that one in first.cheers tony
I'd keep it as a souvenir and buy a GT kit.
Re: imola woes
Posted: Mon Dec 10, 2012 10:08 pm
by carlos fandango
Yes you can but it dosent need a rebore, it just needs stripping, welding and relining. Take it to a reputable scooter shop Scooterotica ,Readspeed, MB, JB, chiselspeed cam lam , etc etc. there are plenty about and should be about £140+ add onto that a piston. Or send it direct to Langcourts or aptec who AFAIK are the only two places that do it and where everyone send them too. This should be the same price as the shops eg. £140 ish and you'll need to send the piston to them at the same time.
If your in any doubt about what, you want id take it to a scooter shop, and you'll benefit from there advise at a similar cost ;)
Re: imola woes
Posted: Mon Dec 10, 2012 11:04 pm
by tonytoolbox
cheers for everyones comments its a good kit so will look into a repair me thinks,its gonna take to much polishing to make it clean enough to go on the mantel ;) mind you them new gt kits look gr8
Re: imola woes
Posted: Mon Dec 10, 2012 11:34 pm
by joespeed
tonytoolbox wrote:cheers for everyones comments its a good kit so will look into a repair me thinks,its gonna take to much polishing to make it clean enough to go on the mantel ;) mind you them new gt kits look gr8
tony check your pm's
Re: imola woes
Posted: Tue Dec 11, 2012 10:05 pm
by Chuck IT
Send it to Darrel Taylor for tuning & have it bored to 66mm with a 116mm rod . Awsome !!!
