converted hub break tool
Posted: Sun Dec 09, 2012 2:38 pm
by RICSPEED
some one posted up a pic of a hub with two cut outs for checkking shoe contact and skimming with sand paper on the lining .. any one have the pic ??
Re: converted hub break tool
Posted: Sun Dec 09, 2012 8:39 pm
by Angry Bloke
Posted: Sun Dec 09, 2012 8:43 pm
by RICSPEED
thanks
Posted: Wed Dec 12, 2012 3:18 pm
by Monty
This is mine it has a sharp blade that I found if I get the blade to fit the shoe in this position then wind in the adjuster I can move the hub round by hand and it shaves off the high spots till Im all the way round, works for me
Posted: Wed Dec 12, 2012 3:28 pm
by RICSPEED
great
Posted: Wed Dec 12, 2012 3:40 pm
by DaveTomo
Oooh! I like that
Think I'll have a go at that myself
Posted: Wed Dec 12, 2012 8:32 pm
by Angry Bloke
^ Great piece of home engineering - think I will change mine
Posted: Wed Dec 12, 2012 8:37 pm
by WINTERMODEL150
Same here too ,mines sh@t compared to this one!!
Dean
Posted: Wed Dec 12, 2012 8:56 pm
by Monty
I described the use wrong you need to line it up with the fixed pivot end then put a couple of turns on the adjuster. The blade is a bit of mild steel with an edge ground in it. Funnily enough it took perfect solid shavings off with the top shoe needing a lot more off it than the bottom shoe. The bloody hub tried to kill me at the IOW so it can be useful and give me good brakes as reconpense
Posted: Wed Dec 12, 2012 11:27 pm
by RICSPEED
just to be clear i wanted a hub cut so i could check the shoes in relation to the miss machined cam hole on Indian 200 cases ... getting hold of a skimming tool is not an issue ... tom petch has one as does rayspeeds
