GP cable length
Posted: Wed Nov 28, 2012 5:30 pm
by poppygun
hello all
Can somebody please tell me the correct length of a GP clutch outer cable as they always seem
to long
thanks poppygun
Re: GP cable length
Posted: Wed Nov 28, 2012 7:41 pm
by squeakmillward
poppygun wrote:hello all
to long
thanks poppygun
Lambretta GP Cable Length Barrel Type Housing Length Housing Diameter Cable Thickness
Front Brake 170cm 67" pear or barrel 144cm 56.5" 6mm 2mm
Clutch 224cm 88" pear or barrel 170cm 67" 6mm 2mm
Gear (x2) 179cm 70.5" barrel 151cm 59.5" 6mm 1.5mm
Choke 46cm 18" mini barrel+slide 39cm 15.5" 6mm 1mm
Rear Brake 102cm 40" None 69cm 27" 7.5mm 2.5mm
Throttle 132cm 52" barrel+ slide 122cm 48" 6mm 1.5mm
Fuel Line 20cm 8" n/a n/a n/a n/a 1/4"
Re: GP cable length
Posted: Wed Nov 28, 2012 7:55 pm
by Doom Patrol
I'm very impressed squeak. 8-)
Re: GP cable length
Posted: Wed Nov 28, 2012 11:53 pm
by Timbo
MB do their own which are the correct length and nylon lined....
