SIL stage 4 barrel
Posted: Sat Nov 24, 2012 6:59 am
by no-hair
What is the max a stage 4 barrel can be taken out to :fb:
Re: SIL stage 4 barrel
Posted: Sat Nov 24, 2012 11:51 am
by nelson pk
Do you mean bore size or port durations?
Posted: Sat Nov 24, 2012 8:07 pm
by no-hair
Barrel bore
Posted: Sun Nov 25, 2012 6:57 pm
by Steve J
Don't know about a SIL barrel, but I've got an Indian 200 barrel for a three wheeler, where the barrel is cast completely around the stud holes (just like the SR185 barrels.) I reckon you could bore that to well over 80mm before you got a pile of cast iron rings on the floor under the boring machine. Not a lot of point, because beyond 78mm you've broken into the stud holes, and beyond 75mm the spigot has already disappeared completely! Regardless of the barrel, the bottom part of the spigot (around 74mm O/D) seems to be the limiting factor, it's just that a barrel with thicker walls higher up is less likely to warp at bores of 70mm and above. Maybe 71 to 72mm is the absolute limit to keep the spigot attached....
Posted: Sun Nov 25, 2012 10:32 pm
by drunkmunkey6969
Anyone else got one of these barrels? I'd like to see one, I have an idea......
Posted: Sun Nov 25, 2012 11:54 pm
by sean brady scooters
i have one Dan lol
Posted: Mon Nov 26, 2012 12:37 am
by drunkmunkey6969
One more reason to tidy the workshop.....! ;op
