my set up is
TS225
tm35
pm pipe
v force reeds
static timing 18 deg
so what could have caused this to happen to my racetour piston?
cheers
scotty
all ports where chamfered but it has worn one side of the exhaust port away on the barrelguygrrr wrote:looks like the ring got caught inna port. but rather then snapping, as it's wire drawn, it tried to pull the top of the piston off. did you check yr bore for damage? are the ports properly chamfered?
will try and get some postedsoullad wrote:any chance of a pic of the underside of the crown?
langcourt AlDiablo wrote:Where did you get it replated?
