Doing the shimmy!!!
Grumpy225
Wee Mark wrote:SORRY....for late reply!!!.....i managed to get it shimmed up with am MB undersized shim 1.70 with no use for the hub end shims (of course as said these would have opposite effect).... for information both Cam Lam & Beedspeed have even thinner shims
Good to know about the thinner shims being aviable. I've always run it to needing super thick ones or .05 difrence but never super thin ones.
Out of currisioty where did you end up with the clearence in the gearbox?
Wee Mark
Main scooter: Lambretta TV200
Hello Grumpy, it shimmed at the smallest clearance acceptable 0.07mm which i was pleased about as it will mean that it has plenty of wear margin and i will be running in the whole engine as its brand new componants all the way through. The box spins in all gears with a little resistance.....oh by the way the MB shim was just under 1.70 as they etch them this was marked 1.68, hope this helps, good luck with any further shimming you has to do.....stick with it!!!
all the best
Mark
    Users browsing this forum: Amazon [Bot] and 25 guests
