float height
jonny snatchsniffer
been reading a bit about this, dellorto, keihin, mikuni etc all have there specs for this but it seems its not set in stone and differing setups benefit more from adjusting this, regarding reed, piston ported, or rotary, do any of you play with this setting ?
