SIL stage 4 barrel
no-hair
What is the max a stage 4 barrel can be taken out to :fb:
nelson pk
Do you mean bore size or port durations?
no-hair
Barrel bore :mrgreen:
Steve J
Main scooter: Lambretta GP200
Don't know about a SIL barrel, but I've got an Indian 200 barrel for a three wheeler, where the barrel is cast completely around the stud holes (just like the SR185 barrels.) I reckon you could bore that to well over 80mm before you got a pile of cast iron rings on the floor under the boring machine. Not a lot of point, because beyond 78mm you've broken into the stud holes, and beyond 75mm the spigot has already disappeared completely! Regardless of the barrel, the bottom part of the spigot (around 74mm O/D) seems to be the limiting factor, it's just that a barrel with thicker walls higher up is less likely to warp at bores of 70mm and above. Maybe 71 to 72mm is the absolute limit to keep the spigot attached....
Anyone else got one of these barrels? I'd like to see one, I have an idea......
i have one Dan lol
One more reason to tidy the workshop.....! ;op
    Users browsing this forum: Google [Bot], Semrush [Bot] and 22 guests
