vespa rally forks
Posted: Mon Nov 19, 2012 4:34 am
by gp200ts1
has anyone got the bearing numbers for the bearings in rally forks so i can pick them up from a bearing stockist?
also the oils seal sizes.
thanks
Paul D
Re: vespa rally forks
Posted: Tue Nov 20, 2012 11:30 am
by GLscoot
Are you a member of the VVC as Bill Drake is very good on these parts. He may even have a set and is very reasonable price wise. SIP also give you the dimension of the bearings, which may help when you go to your local shop. If SIP can't help Scooter Center also put the dimensions on there website.
The price of bearings is a joke, I don't get it. Half the price if you it them from a local bearing shop.
Gary
Posted: Sat Nov 24, 2012 9:01 am
by mickymidas
SKF bearing numbers....6201. 6203.....
