Page 1 of 2
ScootRS antidive question.
Posted: Sun Nov 18, 2012 7:53 pm
by ArKaTxU
Hi.
I have to cut this piece of antidive to operate correctly?
Thanks!
Re: ScootRS antidive question.
Posted: Sun Nov 18, 2012 8:18 pm
by soulsurfer
Yep!
Posted: Sun Nov 18, 2012 9:00 pm
by RICSPEED
i know you do on lth type but before you do .. disconnect the tie bar and try to move the caliper up and down .. if it wont move then peg will have to come off
Posted: Sun Nov 18, 2012 9:10 pm
by ArKaTxU
RICSPEED wrote:i know you do on lth type but before you do .. disconnect the tie bar and try to move the caliper up and down .. if it wont move then peg will have to come off
With the tie bar disconnected the caliper moves up and down without problem. The caliper part and the other part are independent.
Posted: Sun Nov 18, 2012 11:51 pm
by jason frost
No its just holding the speedo drive.
Posted: Mon Nov 19, 2012 12:05 am
by shocky
yes both halfs of the hub need to rotate its a shame to cut a set of jet links though
Posted: Mon Nov 19, 2012 1:15 pm
by tea5ive
dont cut the link stub, cut the locating slot off the speedo cover. check this post out as i did this to my set up, bare in mind i did not need the speedo drive for my aplication. http://scooterotica.org/forum/viewtopic.php?f=7&t=22610
shocky wrote:yes both halfs of the hub need to rotate its a shame to cut a set of jet links though
Posted: Mon Nov 19, 2012 1:39 pm
by ArKaTxU
OK, then i understand that both halfs need to rotate.
And if I cut the speedo part is ok?
What part stop the speedo part rotate free? the speedo cable?
Posted: Mon Nov 19, 2012 3:46 pm
by Minority
As long as the caliper is free to rotate you shouldn't need to cut anything.
Posted: Mon Nov 19, 2012 4:53 pm
by RICSPEED
Minority wrote:As long as the caliper is free to rotate you shouldn't need to cut anything.
as i have said and have also repled on face book to say the same
