vespatronic
Posted: Sat Nov 17, 2012 11:00 pm
by dilan
hi i am looking at converting my smallframe to a vespatronic ignition my problem is what size do i need. the engine is according to the engine number a pk 80 but if already tuned to a 130 parmakit 30mm dellorto carb with 30mm reed valve , full circle crank and zirri gear box and a jl reedspeed down and forward pipe can any one help cheers
Re: vespatronic
Posted: Sun Nov 18, 2012 12:12 am
by lambro
Whip the flywheel off and measure the one you have now.
I use a very-near gauge for this.
Small or large taper is the deciding factor.
