carb rubbers
Posted: Fri Nov 16, 2012 8:49 pm
by roadrunnerian
i seem to be going through carb rubbers every 100 mile or so.they seem to split at the manifold end.i have a mb inlet manifold with a tmx 35mm carb on a ts1 225. i have noticed the carb is right up against the engine mount. has anyone else had this problem and how did they sort it thanks
Re: carb rubbers
Posted: Fri Nov 16, 2012 10:00 pm
by Muppet
roadrunnerian wrote:i seem to be going through carb rubbers every 100 mile or so.they seem to split at the manifold end.i have a mb inlet manifold with a tmx 35mm carb on a ts1 225. i have noticed the carb is right up against the engine mount. has anyone else had this problem and how did they sort it thanks
yeah; so i took da panal off
Re: carb rubbers
Posted: Fri Nov 16, 2012 10:59 pm
by bizzly
Have you tried twisting the carb round so its offset away from the mount. Thats what I have to do to mine as the fuel pipe was touching the mount. I also use offset cones which helps slightly.
Re: carb rubbers
Posted: Thu Nov 22, 2012 11:51 am
by Tosh
Blue Silicone Fuel & Oil Hose Elbow 90 Degree 35mm from autoperformanceonline, try this firm ian just make sure its for fuel and not hot air or water
Re: carb rubbers
Posted: Thu Nov 22, 2012 12:06 pm
by ssteam177
Tosh wrote:Blue Silicone Fuel & Oil Hose Elbow 90 Degree 35mm from autoperformanceonline, try this firm ian just make sure its for fuel and not hot air or water
I use the same as above cut 5mm longer than std carb rubber and has worked a treat for me on my monza with tmx35
Re: carb rubbers
Posted: Thu Nov 22, 2012 8:20 pm
by corrado
Could be caused by the carb hitting the rear footboard on full suspension travel. A mate had this problem but it was knocking the carb off rather than splitting the rubber. Get a couple of portly squire mates to try it out off the centre stand. I agree about the silicone hose too, you can cut it to suit your specific requirement.
Re: carb rubbers
Posted: Thu Nov 22, 2012 8:36 pm
by roadrunnerian
hi thanks for the replies i don't have rear foot boards,will try twisting carb from engine mount also will try the blue tubing as well thanks tosh m8.might file off the overflow pipe holder as well.
Re: carb rubbers
Posted: Thu Nov 22, 2012 9:52 pm
by bizzly
roadrunnerian wrote:might file off the overflow pipe holder as well.
I also did that...forgot to say...lol
