Fitting front dampers to a spanish series 2.
Posted: Fri Nov 16, 2012 2:00 pm
by Ihateyoubutler
Turning front mudguard type. Just want to put skinny dampers on. Not stripped yet but wondered if there are going to be any problems? Looks like the side mudguard brackets might be in the way?
Thanks for any help.
Re: Fitting front dampers to a spanish series 2.
Posted: Fri Nov 16, 2012 2:18 pm
by RICSPEED
spanish series 2 tv175 had them so as eden said ;)
Posted: Fri Nov 16, 2012 3:34 pm
by Bofs
Handy enough just make sure you fit the dampers before fitting the mudguard :oops: ;)
Posted: Sun Nov 18, 2012 12:01 am
by Donnie
Got some on mine, you should have no bother with slim ones, I have the fatter escorts on mine with no issues.
It's a bit "blind" fitting the top of them under the mudguard when replacing but it's easily enough done to be fair.
