piston advice
dave wheeler
have a 63 tv175 needing a new piston but genuine tv pistons seem thin on the ground, i ordered a vertex off camlam but when it came it was a 3 ring piston{minus gugeon pin n rings!}, would i be better off with an indian made 2 ring or stick with this 3 ring, bikes more or less standard and i dont intend tuning it or changing the crank to use a conversion piston
thanks
dave
bristolmod
using one of these:-
http://www.scooterrestorations.com/lamb ... 4mm-mahle/
absolutely no problems for a standard engine
Chris
Scootering since 1968.
dave wheeler
hi chris
tanks for that but sadly its a 62.6mm im needing
Spanish Fly
Main scooter: P200e
Suzuki TS185 Piston? :?
