Page 1 of 2
Amal Mk2 Concentric 2 or 4 stroke?
Posted: Fri Nov 09, 2012 7:36 pm
by DaveTomo
Can anyone confirm whether this is a 2 or 4 stroke Amal.On the back is 2930-1.Mate reckons it maybe a 4 stroke :? got it at a parts fair for £20 with the manifold and its got 2D1 needle.
Re: Amal Mk2 Concentric 2 or 4 stroke?
Posted: Fri Nov 09, 2012 7:44 pm
by Muppet
2
Posted: Fri Nov 09, 2012 7:53 pm
by gerryjunior
I may be wrong but, i think thats from a 4 stroke ( norton i think), the 2 stroke amal carb's had a slope in the brass spray tube not a cut out,
Posted: Fri Nov 09, 2012 8:38 pm
by rosscla
2d1 is a two stroke needle, that spray type is the same as three carbs I have lying about in the front room, although in one of those the tube is flush with the Venturi, whereas the other two it sticks up like that.
Posted: Fri Nov 09, 2012 8:53 pm
by Muppet
its a 2 stoke amal the 4 stroke asnt got a cutaway in the tube
Posted: Fri Nov 09, 2012 8:54 pm
by gerryjunior
Like i said i could be wrong, im more used to the amal mk 1 ..
Posted: Fri Nov 09, 2012 9:45 pm
by DaveTomo
Muppet wrote:its a 2 stoke amal the 4 stroke asnt got a cutaway in the tube
Thank you all,much appreciated,chuffed its a 2 stroke as I've just bought another one "blind" and its exactly the same.Someone had one on a Lammy awhile back at the wickstead parts fair,heard it start up and it took me back ,the induction sound is different I think to that of a dellorto,sort of like a dellorto with a 40 a day smoking habbit.Just fancied putting one on over the winter months and see how it goes - rapido 225.Again thank you.
Posted: Sat Nov 10, 2012 3:01 pm
by Lamaddict
Best carbs I've had but very thirsty.
Posted: Sat Nov 10, 2012 3:05 pm
by bristolmod
I'm going back a long time now to 1968, and the only Amal Concentric carb I saw on a Lambretta needed "tickling" (small button on top?) before you could start it.
Anyone know if I'm right or simply getting senile......
Posted: Sat Nov 10, 2012 4:04 pm
by warts
I think you're right Chris.
For those too young, you pressed a small button on top of the float bowl, this pushed down the float, and the carb flooded - you soon learned how much to give it, or carry lots of spare plugs.
