Locking in 1st at stop
Posted: Thu Nov 08, 2012 10:15 am
by Devo McDuff
How do,
Got my Series 2 Li 150 (with Mugello 186) back from the scoot shop the other day as the kickstart shaft had snapped internally. Running pretty well but since then if I try to change to neutral from 1st while at a stop it won't budge until I start moving again (or stall/kill engine). Not the end of the world as if I'm coming to a red light or whatever I just shift it to neutral before stopping but it is a pain in busy traffic and worried it might mean a bigger problem is on the way.
Any ideas what this would be?
Ta,
Dan
Re: Locking in 1st at stop
Posted: Thu Nov 08, 2012 11:20 am
by WINTERMODEL150
If the problem has occurred since it's been to the shop then I'd take it back.
It sounds like the clutch needs adjusting to me .
Dean
Posted: Thu Nov 08, 2012 11:45 am
by joeythescooterboy
Dan is there anything you can't break?
Posted: Thu Nov 08, 2012 11:52 am
by Devo McDuff
Haha, nope. Got a tank I can borrow?
Very high compression, shite at starting, worn shaft teeth and a bobbins kickstart meant it was getting kicked over more than it should have done and taking a right beating. That's all sorted now though.
Posted: Thu Nov 08, 2012 11:01 pm
by Timbo
Had similar , def clutch sticking..
Posted: Fri Nov 09, 2012 5:55 am
by Devo McDuff
Ta. Will speak to the shop then.
