Rb20 carb
Posted: Sat Nov 03, 2012 8:26 am
by jamjo
Hi , can anyone Tell us what would be the best carb or what they are using on a rb20 kit we are building AF web site lists the dellorto flat slide carbs and we have told that a mukuni would also work well . Does anyone have any views on either or what would be a better set up . He plans to use a franspeed super tourer exhaust with his set up . Thanks if anyone has any views 8-)
J
Re: Rb20 carb
Posted: Sat Nov 03, 2012 9:31 am
by drunkmunkey6969
Recommend a 30mm phbh for good combination of power and fuel economy.....or 30mm flatslide if he has a few quid to shell out on a nice carb. 34mm flatslide if peak power is main concern, but fuel economy will suffer disproportionately..... 35mm TMX can be used, but is probably overkill on the RB20, isn't as flexible in the mid-range jetting, and is a bit of a mismatch for a tourer exhaust....better suited to a race pipe.
Re: Rb20 carb
Posted: Sat Nov 03, 2012 11:13 am
by mattyp
i would put a 30mm carb on there, ive got a brand new motorforce carb with power jet fitted, new jets £95.00 with post ;)
Re: Rb20 carb
Posted: Sun Nov 04, 2012 7:56 pm
by jamjo
Thanks for the replys
J
Re: Rb20 carb
Posted: Wed Nov 07, 2012 1:05 pm
by Toddy
I used the 30mm Flatslide VHSH performed very well slightly more expensive than the PHBH though
Re: Rb20 carb
Posted: Wed Nov 07, 2012 2:05 pm
by sydduckett
Toddy wrote:I used the 30mm Flatslide VHSH performed very well slightly more expensive than the PHBH though
Same as above really, its what comes with the kit and you will get exact set up details from AF, although if your using a franspeed then you may have to alter the jetting as the kit normally comes with there NK.
