Page 1 of 3
Scooter restorations Jap crank.
Posted: Sun Oct 28, 2012 8:09 pm
by 10 inch Terror
Hi all, would the Scooter restorations up graded crank be any good in an RB22 motor?
Re: Scooter restorations Jap crank.
Posted: Sun Oct 28, 2012 8:10 pm
by Andy Pickering
I'm running the Avanti with one and so far so good
Posted: Sun Oct 28, 2012 8:20 pm
by drunkmunkey6969
Andy Pickering wrote:I'm running the Avanti with one and so far so good
The only reason you run that crank is because its the crank you had in when the kit was fitted and you were on a budget. Its not the crank of choice though for a tuned motor......plus the RB revs much higher than the Avanti.
Posted: Sun Oct 28, 2012 8:23 pm
by drunkmunkey6969
10 inch Terror wrote:Hi all, would the Scooter restorations up graded crank be any good in an RB22 motor?
Get the best crank you can would be my advice. Indian webs are OK with Jap rod/bearing conversions with a TIG welded pin. Off the shelf, the minimum i'd go for is a MEC EUR 'black' race crank - the version with shims in. They cost about £50 more than the crank you have seen....but its £50 well spent.
Posted: Sun Oct 28, 2012 8:37 pm
by Andy Pickering
The cranks got the Jap bearing.
Posted: Sun Oct 28, 2012 10:02 pm
by drunkmunkey6969
I know Andy....but not a Jap rod and its not TIG welded. I'd want it TIGd up in an RB. Not sure exactly which Jap bearing they use either, I use the silver caged ones.
Posted: Sun Oct 28, 2012 10:35 pm
by Andy Pickering
Ah well bin the rb and get yer sen an Avanti :grin:
Posted: Mon Oct 29, 2012 1:32 pm
by Toddy
drunkmunkey6969 wrote:I know Andy....but not a Jap rod and its not TIG welded. I'd want it TIGd up in an RB. Not sure exactly which Jap bearing they use either, I use the silver caged ones.
Agreed the RB needs a good crank it will find any weakness
Posted: Mon Oct 29, 2012 2:41 pm
by Adam_Winstone
I've put one of these cranks into a mate's iron 175 a couple of years ago. He has since done the last 2 Euro Lambretta rallies and others without issue. These cranks are perfectly good for this type of motor but fitting anything other than a top rate crank to an RB is a complete waste of time. Whilst the Scooter Restorations cranks have very good webs and bearings, the conrods don't look great and I can't remember whether or not they have suitable big end shimming.
If you rang Scooter Restorations and asked them if this crank was suitable for RB motor use then I expect that even they would point out the limitations of these cranks, whilst the motor that you are considering fitting it to is a top performance kit which will put real strain on any crank that you choose to fit.
Adam
Posted: Mon Oct 29, 2012 4:24 pm
by Bofs
Glasgow Lambretta have the Meceur cranks advertised for £90, best deal on them I`ve seen.
http://www.glasgowlambretta.co.uk/gl_parts.html
