Page 1 of 2
PX200 flywheel diameter?
Posted: Fri Oct 26, 2012 3:18 pm
by Adam_Winstone
Anyone know what the diameter of a standard PX200 flywheel is (accurately)?
Ta
Adam
Re: PX200 flywheel diameter?
Posted: Fri Oct 26, 2012 3:29 pm
by sean brady scooters
195mm
Posted: Fri Oct 26, 2012 4:51 pm
by Adam_Winstone
sean brady scooters wrote:195mm
Ta
Posted: Sat Oct 27, 2012 3:14 pm
by Adam_Winstone
Thanks for the info. Mate's timing now set up on his Malossi 210 + 60mm stroke crank, which had just holed a piston, even though it had been dyno'ed and fitted with a correctly profiled + road compression head, and fast flow fuel tap.
It may be of interest/use to some of you to know that his stator (possibly not Piaggio, perhaps LML) would only allow it to fire at just over 20 degrees btdc, even though it was turned fully clockwise on the stator, which should have been correct for this kit. We elongated the stator slots and now have it firing at 18 degrees btdc, with him under strict instructions to keep an ear out for pinking and an eye on plug colour. We have also fitted by a very impressive flow SIP (I think) fast flow tap as the previous fast flow tap wasn't actually all that fast.
With any luck his issues will now be resolved but I thought it worth pointing out to all that full rotation on some PX stators will not give you 18 degrees!
Adam
Posted: Sat Oct 27, 2012 4:33 pm
by bazman
Yeah quite common this Adam, even on genuine stator plates. had to elongate the holes on my old 210 to get anywhere near 18 deg.
Also fitted a stator this week to a mates p2 and for 21 deg it was between the A and IT marks on the stator, always check with strobe etc !
Posted: Sat Oct 27, 2012 5:08 pm
by Adam_Winstone
^... not just a freak odd one then.
This had all the tell tale signs of being ignition related but without obvious markings to follow, the owner had just followed the instructions and rotated it fully clockwise. Yes, it really does go to show just how important it is to double check everything and not simply rely on what you might take for granted. Obviously, this is especially true when you start to mix and match components from different sources.
Adam
PS - Ooh, my first Vespa post!
Posted: Sat Oct 27, 2012 6:27 pm
by bazman
Oooh , whip yourself and 7 hail marys and hope/pray to god no one from the other side see's this
Posted: Sat Oct 27, 2012 7:44 pm
by Adam_Winstone
bazman wrote:Oooh , whip yourself and 7 hail marys and hope/pray to god no one from the other side see's this
Yeah, reminds me of going to a Banbury SC do in a Vespa (Vespa riding mates) T-shirt and seeing all my mates rolling around in laughter and taking photos of me
I've had Vespas and think that they are very good machines, however, I bought my first Lambretta and broke down on my way home! I soon understood that I was going to need a manual and tools, and learnt that I had nobody to blame but myself if I broke down. During this time I still had P-ranges and never had to fix them, nor buy workshop tools, which meant that I had to pay someone else to do Vespa work for me! I didn't like that much (tight as!) so made my mind up to go Lambretta. You could say that my affiliation to Lambretta is a direct result of the reliability of Vespa
Thankfully, I did learn that a well built and maintained Lambretta is just as reliable a scoot as its Vespa counterpart, and recognise that they are both excellent machines. That said, I tried riding a standard P2 Disc a couple of years back and found it completely alien to me. It had electric start, great lights, comfortable seat, good instrumentation, didn't vibrate, was quiet and reliable.... it just wasn't for me
Adam
Posted: Sat Oct 27, 2012 8:19 pm
by bazman
Yeah my feet are firmly set in both camps, done my time on vespas as a young scooterist doing many rallies, I needed a reliable workhorse as had loads of miles to cover , but had a couple lammys in that time too, more recently ( last few years ) soley lambretta.
But bought an old motovespa p2 this year and love it totally different to the ts1 but more enjoyable doing the miles albeit at a slower pace.
Posted: Tue Oct 30, 2012 10:27 pm
by soosh
Adam_Winstone wrote:Anyone know what the diameter of a standard PX200 flywheel is (accurately)?
Ta
Adam
You should know this really
