Macsi/fuel pump plumbing
Posted: Thu Oct 25, 2012 6:17 pm
I'm building a fast touring P-200 E. Here's the spec. Worb 5 Mushroom long stroke crank, Pinasco kit, German Market TM 27 carb, MBD reed, SIP carb manifold, Macsi boost bottle, SiP fast flow tap and JL Right hander.
Do I need to fit a fuel pump? If so, can I plumb it to the same brass bung that the Macsi boost bottle is attached to via a "Y". I would use a Mikuni vacuum operated diaphram pump if I needed one. I am not using a extended range tank.
