Page 1 of 2
now for the rear brake light ! help
Posted: Tue Oct 23, 2012 7:55 pm
by rbgaz
right wired rear light to battery that was easy even for me , now how do i do brake light ? i have the wiring going to my front brake lever i have taken the live off that and touched a live feed from battery and it comes on really bright so is it just case of joining these two together then plugging it back into lever ?
Re: now for the rear brake light ! help
Posted: Wed Oct 24, 2012 8:05 am
by rbgaz
anyone ?
Posted: Wed Oct 24, 2012 8:49 am
by ArmandTanzarian
You just need to route the power feed for the brake light via the switch. That way, when you pull the lever, the switch closes and on comes the light. Its a little more complicated if you want to use the rear brake light switch as well but not much. Draw it out on paper to get your head round the circuit and it soon becomes obvious what's needed.
Posted: Wed Oct 24, 2012 6:28 pm
by byron
simple brake light wiring :
Posted: Thu Oct 25, 2012 2:18 pm
by firekdp
rbgaz wrote: i have taken the live off that and touched a live feed from battery and it comes on really bright so is it just case of joining these two together then plugging it back into lever ?
You can't just connect a DC feed to the front brake switch because the rear switch is getting AC via the MB loom. When both brakes are used at the same time you will probably blow a fuse or damage the stator.
Posted: Thu Oct 25, 2012 2:56 pm
by coaster
I take it this is for a DC conversion? If so, just follow Byron's diagram, the feed form the regulator will. Be DC already. If not, then Firekpd has the truth of it, you won't be able to mix the 2.
Posted: Sat Oct 27, 2012 12:13 am
by rosscla
byron wrote:simple brake light wiring :
This how I did mine as well, but skipped the connection with the headset bulb holder an ran it direct to one side of the rear switch.
Posted: Sat Oct 27, 2012 8:20 am
by rbgaz
way over my head think i need to find adult lol but on the plus side i have the park light working with rear of the battery :bigsm: what about the horn has it its own power lead that i can pull out and replace with battery feed ? also ive just brought some tiny discreet bullet lights from bikevis any one else used them ? http://www.bikevis.com/store.html
Posted: Sat Oct 27, 2012 8:53 am
by Minority
rbgaz wrote:way over my head think i need to find adult lol but on the plus side i have the park light working with rear of the battery :bigsm: what about the horn has it its own power lead that i can pull out and replace with battery feed ? also ive just brought some tiny discreet bullet lights from bikevis any one else used them ? http://www.bikevis.com/store.html
DC horn conversion pretty well covered here:
http://scooterotica.org/forum/viewtopic.php?f=7&t=23970
Posted: Sat Oct 27, 2012 11:51 am
by firekdp
If you are running a DC feed to the headset??, Then your best bet would be to use this new feed wire as AC direct to the headset. Then use the original MB loom brown for the DC side as this feeds everything, you are asking for, on the way to the headset ie. brake light and horn.
