Exhaust change & carb jetting
vRSG60
Main scooter: Lambretta Li125 Lambretta GP20
My S3 Lambretta runs an SX150 engine with (so I was told when I bought it???) a 175 kit. The carb is a Dellorto SH1/20 (don't know what the jets are).
I fancy a new exhaust, more for the looks than any performance gain. Would fitting a ScootRS exhaust have any adverse effect? Or would I need to increase jets/carb size?
I get my kicks out on the floor.
bristolmod
you really need to establish what your existing set up is before deciding on another exhaust.
Is it 175?
What jets/ atomiser/ slide etc etc
Scootering since 1968.
vRSG60
OK further to this my carb settings are as follows -
Slide - 5914-1
Atomiser - 5899-2
Main Jet - 106
Pilot Jet - 45
Stater Jet - 50
I haven't taken the barrel off to check so let's assume a 175CC
Any help will of course be greatly appreciated.
bristolmod
that's jetted for a TV175 S3 apart from the starter jet which should be a 50.
That being the case' if you're looking for a tad more performance I'd up the starter to 50 and slap on a 42mm Clubman ( you may then need to up the main to 108- try it and see)
If you're only concerned with looks why not fit a chromed Indian Big Bore, which apparently perform better than a 42mm Clubbie.
Alternatively go with the ScootRs pipe, but you should then consider fitting another larger carb.
Regretably "the world is your lobster" with exhausts/ carbs......
vRSG60
Thanks Chris.
bristolmod wrote:that's jetted for a TV175 S3 apart from the starter jet which should be a 50.
    Users browsing this forum: Google [Bot], Google Adsense [Bot] and 2 guests
