t5 malossi 172 reed kit
Posted: Wed Oct 17, 2012 10:02 pm
by scooter frank
hi all
if anyone could help
rebuilt my t5 mk1 with the malossi reed valve kit and 30 delorto carb and it runs s**t.
not ported anything other than the in let and i was told not to cut the crank.
do i have to port the caseings and do i have to split the crank,ive done many 210s but this is my first t5.
i think i have a fule restriction by not cutting the crank.
any suggestions on a exhaust please.
lookin forward to the suggestions before i port the caseings.
frank
Re: t5 malossi 172 reed kit
Posted: Wed Oct 17, 2012 10:07 pm
by gimp1971
cut the crank and it needs quite a bit off also need to open up the casings Diablo did mine and scorpian works well with a reedvalved 172 or if you can get one a taffy do not use a PM
Posted: Wed Oct 17, 2012 11:29 pm
by sean brady scooters
to reed valve it properly you will require 360 degrees of inlet timing ,this requires a crank and inlet port to be modified extremly .
a half way stage would be to use a crank that is cut/ slashed back like a rotary valve race crank would be at least .
but to put on a reed block onto a std crank is just futile as you are just introducing a restriction as you have found out .
Posted: Thu Oct 18, 2012 11:28 am
by joeythescooterboy
I had a T5 crank done a while back for a reed motor, absolute work of art, think the fella that did it was called Sean ;)
Posted: Thu Oct 18, 2012 4:13 pm
by gimp1971
pro porting did mine
Posted: Thu Oct 18, 2012 8:38 pm
by scooter frank
well thank you every one for that us full information,i thought it wasnt a bolt on kit,i did ask at midland if i needed to cut a t5 crank and they said no,should stick with me instincts.
my m8 has built many tuned scoots but never done a t5.
thanks again everyone :D :D
Posted: Sun Oct 21, 2012 9:39 pm
by scooter frank
sending my crank of tmorra so i will keep you informed.
thanks again
Posted: Sat Nov 03, 2012 6:42 pm
by scooter frank
thank you all again for your reply's,i have now installed the crank witch i must admit its a work of art and its turned out better than expected,
the cases were ported and cut to the malossi kit and a 140 main and a 60 idle and shes running really sweet.
thanks again
http://i333.photobucket.com/albums/m380 ... 12_11_.jpg
