I didn't get any with the shock.
Anyone got them that they could email?
BGM Rear Shock Instructions
- soulsurfer
- registered user
- Contact:
What's your email address Bilko?
- soulsurfer
- registered user
- Contact:
PDF sent
For the benefit of others TBH the instructions are too complicated, so I, and many others just set the rebound with about and inch of thread at the top of the spring and set the compression on the middle click, tighten or loosen the spring for a harder/softer feel.
sydduckett
- registered user
- Contact:
Are your instructions for the first ones or the later ones with the extra adjustment? If its the earlier can you mail me a copy as well....pleasesoulsurfer wrote:PDF sent
- soulsurfer
- registered user
- Contact:
Dunno, but sent anywaysydduckett wrote:Are your instructions for the first ones or the later ones with the extra adjustment? If its the earlier can you mail me a copy as well....pleasesoulsurfer wrote:PDF sent
For the benefit of others TBH the instructions are too complicated, so I, and many others just set the rebound with about and inch of thread at the top of the spring and set the compression on the middle click, tighten or loosen the spring for a harder/softer feel.[email protected] ta
When you say extra adjustment, do you mean 40 clicks for rebound instead of 16?
Hi Guys,soulsurfer wrote:PDF sent
Did this setup method work out to be ok?
As per previous thread I received no instructions, 1’’ exposed thread seems like a lot of compression?
thanks
11111111 = 0xFF
- soulsurfer
- registered user
- Contact:
Also at http://jet200.com/catalog/product_manuals.php if you don't want to download.
