Beedspeed hydraulic kit
Posted: Tue Oct 16, 2012 11:47 am
by brucie
Looking to have a go at fitting this on my Mk1 PX.
Does anyone have a photo of the handlebar mount fitted. looking to see how much or little metal to remove to fit it and how easy or hard it was.
And how to route the hydraulic hose.
http://beedspeed.com/product_info.php?c ... ts_id=5755
http://beedspeed.com/product_info.php?c ... ts_id=6383
CHeers Bruce
Re: Beedspeed hydraulic kit
Posted: Tue Oct 16, 2012 1:58 pm
by soulboy
bloody hell will be looking into getting one of them looks very good
Posted: Tue Oct 16, 2012 2:11 pm
by JINX
That does look good.
If you want to avoid trimming the headset, I have a bracket that fits up to the mirror mounts from underneath. I had mine made in bar stock steel for cheap.
I have a dimensioned drawing. It puts the lever right where you would want it. My headset is a sprint V, but the design could be modified.
http://www.flickr.com/photos/59397025@N03/5436418356/
Posted: Tue Oct 16, 2012 2:28 pm
by ArmandTanzarian
This is for the ScootRS one but the principle is the same
http://www.nycscootering.com/2011/03/28 ... e-upgrade/
Edit: Actually the mounting looks different! but its another way to do it.
Posted: Tue Oct 16, 2012 5:08 pm
by gaz_powell
i made a few of those brackets up - worked a treat
goldeneye and pollossi220 who come on here got one each off me
the beedspeed one throws the lever out
sorry cant make them any more !
Posted: Wed Oct 17, 2012 4:49 pm
by GLscoot
There are several brackets out there, SIP have a few. Why not go the semi hydraulic road. Other than that I am not sure if you can drill a hole in the fork tube to feed the hose up through on the P range. If you google Hell or Goodridge, they can make you up a hose in any colour and length you want. But I would first look at the semi hydraulic set up, done right looks good.
Gary
Posted: Wed Oct 17, 2012 10:04 pm
by gimp1971
i got one on my drops and they were really easy to fit will take some pics but prob wont be till weekend
Posted: Fri Oct 19, 2012 3:20 pm
by roadrunnerian
i used a mounting brkt off a px disc and had it welded to my mk1 t5 looks good and fitted the brake pipe down through the forks to a beedspeed front disc brake conversion. did have a scoot rs one but changed it due to bad brake judder on application.
