Page 1 of 2
Escort Front Dampers
Posted: Sun Oct 14, 2012 3:32 pm
by Devlam
I've just fitted a pait of the slim escort front dampers. Should they be parallel with the fork tubes?
The bottom damper stud in the link seems to push the bottom out relative to the top bracket, doesn't look quite right??
If anyone has a pic of their dampers from straight on that might help.
Cheers.
Re: Escort Front Dampers
Posted: Sun Oct 14, 2012 3:53 pm
by RICSPEED
have you simply replaced dampers? if so where they ok before? or have you used the bolt on type brackets ??
Posted: Sun Oct 14, 2012 4:00 pm
by Devlam
They're new forks with welded brackets and MBD links and studs.
Posted: Sun Oct 14, 2012 4:08 pm
by RICSPEED
well .. i got some new forks .. i had to cut the top brakets off as they were in the wrong place .. admittedly i was being fussy
Posted: Sun Oct 14, 2012 5:52 pm
by shocky
its normalish what damper studs are you using
ive don alot of forks for people and i dont put the top brackets on unless i have links and damper studs fitted ive found that the MBD links and damper studs make the top bracket out by 6mm I AM NOT KNOCKING ANY PRODUCTS I email mark with my concerns and he said it was normal for the innocenti forks to have the dampers tilting in at the top
Posted: Sun Oct 14, 2012 7:28 pm
by Devlam
Thanks both of you for your replies
Shocky -- I didnt measure it but I reckon your 6mm out is about spot on - they are MBD studs.
The gap in the bracket on the forks was wide enough for a penny washer either side of the damper, I've put a couple on one side just to get in the best position. I think it will be ok, and I can live with it, just wanted to check I hadn't missed something daft.
Cheers.
Posted: Mon Oct 15, 2012 10:45 am
by dapper
If you look at Shocky's bottom photo, you can get the shoulder turned down on the link stud which will bring it back in line and make the shocker parallel.
Posted: Mon Oct 15, 2012 12:04 pm
by shocky
dapper wrote:If you look at Shocky's bottom photo, you can get the shoulder turned down on the link stud which will bring it back in line and make the shocker parallel.
hi mark i was wondering if u were going to comment i remember you FILED yours didnt you ?
ive always wondered why that shoulder is so big and is often exasperated by people putting a penny washer on top as well altho i know why they do that
Posted: Mon Oct 15, 2012 1:13 pm
by dapper
Hi Steve, hope you are well. Good to see you're still looking in.
The filed link studs are holding up well. Did get another pair and had them turned down properly
They sit parallel from front view and side on
Posted: Mon Oct 15, 2012 4:55 pm
by shocky
hi dave yes im on the up after last year
just use this and the GTS forum now have the odd look at the feckers but dont post anymore
