2002 vespa kits
Posted: Sat Oct 13, 2012 8:57 pm
by weedodger
why do all the kits, malossi, polini, pinasco, all require porting to be done after spending 3-400 quid on a kit? also, why not supply heads with the kit,or supply a proper, bolt on kit!
all i want for my mrs 200 is a kit i can bolt on,with jetting to suit, and an exhaust.....
however, if porting was beneficial, how much would this cost, and where please,
all these kit choices , and iv still not picked one for my gp200 either, christ o mighty! :(
Re: 2002 vespa kits
Posted: Sun Oct 14, 2012 5:09 pm
by Juan
Pinasco 213 will come complete with a cylinderhead and you don't have to port the cases as with Polini and Malossi.
Nice piece of kit if not exactly a Rocketship but they do work a little better with a 'stroker crank if you can be arsed.
Re: 2002 vespa kits
Posted: Sun Oct 14, 2012 9:20 pm
by weedodger
Juan, the mrs 200 is bog standard, what about these new sip cylinder heads? or just the barrel piston and head straight out the box? what exhaust are you running please with it?
Re: 2002 vespa kits
Posted: Wed Oct 17, 2012 10:09 pm
by fraserp200e
If you just want something to bolt straight on try a Harry Barlow stage 4. Do a search on here, there's plenty of info about it.......
Re: 2002 vespa kits
Posted: Sun Oct 21, 2012 9:31 pm
by Juan
Not had one in over 20 years but I had a Fresco on mine, went well for the day. Probably wouldn't bother with them at all today truth be told unless I was doing a period correct Rally 200 in Armando's metalflake colours. Not saying it's a bad kit at all because it isn't but I'd rather go with a Polini
Re: 2002 vespa kits
Posted: Mon Oct 22, 2012 6:19 pm
by dopeshots
