While I'm at it.
Posted: Sat Oct 13, 2012 6:39 pm
by Ihateyoubutler
Is there any way of unbending a bent brake lever without snapping it?
Thanks.
Re: While I'm at it.
Posted: Sat Oct 13, 2012 7:23 pm
by RICSPEED
not with out a lot of heat
Posted: Sat Oct 13, 2012 9:42 pm
by Ihateyoubutler
So how does that work then?
Posted: Sun Oct 14, 2012 1:00 am
by RICSPEED
the lever is very hard .. odd that it bends .. but by all means try bending back with out oxyasetelene and you will find out
Posted: Sun Oct 14, 2012 10:26 am
by bristolmod
do you mean the lever at the handlebar end or the drum end?
Posted: Sun Oct 14, 2012 10:35 am
by Ihateyoubutler
Sorry, handlebar alloy levers.
Posted: Sun Oct 14, 2012 10:59 am
by ArmandTanzarian
RICSPEED wrote:the lever is very hard .. odd that it bends .. but by all means try bending back with out oxyasetelene and you will find out
Now you mention it, it is odd. How is it that you can fall off and bend one like a banana but try and do it deliberately and it will snap.
Posted: Sun Oct 14, 2012 11:45 am
by bristolmod
try putting it into a vice and slowly wind the bend out using the full area of the jaws of the vice
Posted: Sun Oct 14, 2012 4:03 pm
by RICSPEED
only explanation i can muster is that the ally changes at a molecular level .. its perhaps like doing break lines on a car .. you can bend once but then its very hard to bend it back as the tube seems to harden once bent
Posted: Mon Oct 15, 2012 12:24 pm
by shocky
correct work hardens the same as the seize scuff on a piston hardens like glass and wont hold lubrication and will seize in the same area
