Soooo........
Posted: Fri Oct 12, 2012 8:15 am
by DigDug
Why are the Dyno chart runs carried out in third gear?
Re: Soooo........
Posted: Fri Oct 12, 2012 8:57 am
by Darrell Taylor
3rd generally shows the highest power output on a scooter and provides a long enough run to work the engine,small motorbikes 6 speed i run in 4th and its more of a case that your picking a gear as a regular testing regime to provide the best repeatability for yourself and also repeatability for comparison with other dyno,s ,for example you could do
all runs with 30 psi rear tyre pressure
all runs with no rear straps and sat on the bike
all runs in 3rd gear
all runs between 4000 to 9,000rpm
Re: Soooo........
Posted: Fri Oct 12, 2012 9:35 am
by DigDug
Thanks Darrell - It's nice too know these things....
