Hello all,
Who sells a main engine mounting bolt for a wideframe vespa? I can't find one anywhere. Its longer than a P range one.
Wideframe Vespa, Main Engine bolt
- ArmandTanzarian
GLscoot
- Main scooter: Vespa GS150
It's not one bolt, it's two bolts each around 50mm long. These bolts fit the bracket from SIP. I can't remember what size they are. I may have a spare couple of bolts lying around, will let you know.
Gary
Gary
- ArmandTanzarian
If you could tell me the length and size that would be great. Just finding them on the SIP website would be really helpful. Searching on it is always a tricky one because the translation from german is often a bit weirdGLscoot wrote:It's not one bolt, it's two bolts each around 50mm long. These bolts fit the bracket from SIP. I can't remember what size they are. I may have a spare couple of bolts lying around, will let you know.
Gary
http://www.sip-scootershop.com/files/ca ... ex.html#/1
- ArmandTanzarian
Cheers. Although a fastener supplier on ebay was a better deal at £3.50 for two (with nuts and washers) than SIP who wanted nearly a fiver each!
I have a catalogue. I grabbed one at Mersea. And it is indeed brilliant (although it may bankrupt me)
