Vespa electrical issue (v strange what does it mean)???
Posted: Mon Oct 08, 2012 7:15 pm
Scooter started this morning then stopped 5 mins from home totally dead.
As in hurry walked it home got in car then off to work.
Had a look tonight as it wouldnt start at all in the morning.
changed and checked plug then cdi , one of the wires the third was loose so crimped on a bit tighter.
got advised to leave end other green wire out of cdi and started first time!!
However on turning and removing key would not turn off.
put cable in turned off but would not start with wire in???
So ive left the wire out so i can use it every morning but cant understand what the problem is with the end wire on the cdi. Was the same with brand new spare cdi also
Only thing ive done since it was fine was give it a real good top to bottom clean with gunk and jizer in the engine when it was on side so i could get underneath and put new part plug in having hosed down in normal way after cleaning.
Does it mean ive got water some where ??
Any help welcome
Phil
Any help welcome
Phil
