Splitting a P200 crank
Posted: Mon Oct 08, 2012 9:48 am
by mushroom
I need to change the big end bearing but can't find anything online that shows you how to do it
Is it that hard a job that it's easier to buy a crank and conrod complete ?
Re: Splitting a P200 crank
Posted: Mon Oct 08, 2012 10:01 am
by mickymidas
Take a look at Scooterhelp .com ....Might be of some use.
Posted: Mon Oct 08, 2012 10:06 am
by mushroom
I had a look on there and he reckons you need to take it to a mechanic to split the crank
Posted: Mon Oct 08, 2012 4:17 pm
by Ivan_200
you have to press out the pin and realign the halves, almost impossible to do on your own without proper tooling
Posted: Mon Oct 08, 2012 4:27 pm
by mushroom
OK fair enough, looks like I'll just get a new one complete then
Posted: Mon Oct 08, 2012 8:26 pm
by gaz_powell
to split a crank you need a hydraulic press, correct size drifts and correct size wedges to block the webs I can split them at work wouldnt attempt to rebuild them as you need a v block/dial gauge and experience
any good motorbike engineer can do it - i use a local shop he charges £15-20 (labour only) to split, rebuilt and balance
i wouldn`t change the bearing without changing the rod - when the bearing goes it usually takes the inner surface of the big end with it
a rod kit is around £35.00 + so still cheaper than a good crank - if it is piaggio webs and the threads and tapers are good i would rebuild if not buy new
Posted: Mon Oct 08, 2012 8:41 pm
by mushroom
gaz_powell wrote:to split a crank you need a hydraulic press, correct size drifts and correct size wedges to block the webs I can split them at work wouldnt attempt to rebuild them as you need a v block/dial gauge and experience
It was in a seized engine that's now been stripped.
I tried moving the conrod round the crank but it felt stiff and notchy
It's moving easier now but I'm not sure I can rebuild it like that and trust it to be OK
For piece of mind I'll change the lot
thanks for all the advice
