GT 186 kits
watto66
Hello All,
I have recently purchased a GT 186 Kit from Gran Sport not fitted it yet i was wondering (not knowing a great deal about this ) are the ports stage tuned to a level of the shelf so to speak ? , just wondering i intend to have casings matches etc.
Thanks for your help.
storkfoot
Have a read of this and the attachments:
http://www.granturismo.pwp.blueyonder.co.uk/
Rich_T
Main scooter: Li Special
The tuning stages for Lambretta barrels are more applicable to the traditional OEM style barrel. The GT has a reed valve so in some stage terms it might be considered as stage 6 or stage 7. The fact that GT's have large flowed ports and reed valves means that there is precious little ,if any, work to make it perform.
Consequently, it is very hard to technically compare a stock GT kit against a GP200 stage 4 for example. Although one is termed as tuned to stage 4 it is, in actual fact, below the "out of the box" GT specification.
watto66 wrote:...are the ports stage tuned to a level of the shelf so to speak ? ....
isn't that all a load of 80s bar-talk pony anyway..?
match the casing, fit the kit as is, ride and enjoy
Muppet
the gt kit needs the casing matched an ya wood notice the difference?
muppet,
C’est la vie
watto66
Ah thank you all very much , now i understand i was just curious as they say.
Boothy_the_makem
Playstation gamer tag: Phantomkiller_uk
Main scooter: modded t5 classic wi a parker
Are these kits still available ? . ive been weighing up which way to go with my special 125 engine,
if they are can i run it straight from the original crank as i believe they were good uns in the li spec 125. ? i dont want to buy a electronic kit only to have to change to a gp crank and kit,
ive got good compression on the engine and was gonna bolt it all back in, see how it runs for now and maybe slap a 175 kit on it later.
i have a 20mil dellorto and a 22
so whats the best set up for this kit, ( ie exhaust, carb etc ) 60mph will do me . trying to weigh up if it would be worth me spending compared to a 175 .
Canny lass, Geordie girl, he gave her pints and fags and grub and shorts. Canny lass, Geordie girl, she gave him earache and penal warts,Penal warts.
Stokie
watto66 wrote:Hello All,
Why on earth would you go out and buy a kit from a dealer and not ask them anything about it?
joeswoonara
Main scooter: jet ts1
Rich_T wrote:The tuning stages for Lambretta barrels are more applicable to the traditional OEM style barrel. The GT has a reed valve so in some stage terms it might be considered as stage 6 or stage 7. The fact that GT's have large flowed ports and reed valves means that there is precious little ,if any, work to make it perform.
you`ve had a reply from the designer .....i think you can take that as gospel .................
However... if you take a stage of tune as the higher the number, the more peaky and unrideable it becomes, describing a GT as stage 7 is a little harsh.
My GT feels like the way a standard bike should feel. But it's faster, and not wheezy.
    Users browsing this forum: Google [Bot], Google Adsense [Bot] and 1 guest
