Page 1 of 2
H3 Bulbs ?
Posted: Tue Oct 02, 2012 11:26 am
by nellyboyo
Bought a lovely pair of chrome spots of epay for near enough nothing the other day and was planning to fix one low down the legsheilds on my ongoing project . Now I know i`m a bit thick , but when I wire them up to my DC power supply for a test the main H3 type bulbs don`t work ??
I`m obviously missing something ?????? :freak:
All this new tech ...bah
Re: H3 Bulbs ?
Posted: Tue Oct 02, 2012 11:52 am
by RICSPEED
have you wired the spot on a separate switch ?
Re: H3 Bulbs ?
Posted: Tue Oct 02, 2012 12:44 pm
by nellyboyo
No , I just wired up to my bench power supply . I also stuck it across a diesel car battery I had hanging about in case there wasn`t enough current.
Didn`t work ???
Re: H3 Bulbs ?
Posted: Tue Oct 02, 2012 1:18 pm
by RICSPEED
are they dip and main or just single beam spots ?? .. either the bulb is duff or a connection in the holder
Re: H3 Bulbs ?
Posted: Tue Oct 02, 2012 1:59 pm
by nellyboyo
Well... they are single beam spots with a blue led halo. The led halo works ok .
But the main drew a large current from my power supply on both of the units so I was doubtful the bulbs were somehow short circuit in both units .
I`m an instument tech by trade so I`m not that daft
.... I just assumed there must be something I don`t know about this type of bulb ... daft as it sounds ??
Re: H3 Bulbs ?
Posted: Wed Oct 03, 2012 6:28 am
by nellyboyo
Anyone ???
Re: H3 Bulbs ?
Posted: Wed Oct 03, 2012 12:18 pm
by vRSG60
Not a lot to know. The lead is +ve and the body should be earthed to -ve
Re: H3 Bulbs ?
Posted: Wed Oct 03, 2012 3:44 pm
by coaster
vRSG60 wrote:Not a lot to know. The lead is +ve and the body should be earthed to -ve
What he said but you haven't mentioned the wattage of the lamps, they could be anything up to 120watts :shocking: Also you've not mentioned what you are fitting them to, I'd say it's likely that your headlamp will go quite dim when you switch them on unless you arer DC and have a decent battery fitted.
Re: H3 Bulbs ?
Posted: Wed Oct 03, 2012 5:43 pm
by nellyboyo
Well now I feel daft......I`m away at work at the moment so I can`t check.....they are either some huge wattage or dead short ???
I did put them across a big diesel battery I had lying about with no joy.
OK so if they are 120 watt, what a sensible value to put in there ? I`ve got a halogen headlamp and led rear . Its only really for the look I want to fit it.
Re: H3 Bulbs ?
Posted: Wed Oct 03, 2012 6:47 pm
by coaster
