pm tuning pro street levers
smoore-gt225
Main scooter: lambretta GT200
hi does anyone know or have fitted pm tuning pro street levers to a series 2
phoned pm tuning and they didnt know if they would fit :o
cheers steve
they wont .. you would need late indian clutch and throttle lever supports
smoore-gt225
RICSPEED wrote:they wont .. you would need late indian clutch and throttle lever supports
hi thanks do you mean i would have to fit a indian gp type gear change support, i dont need the throttle side as got hydraulic fitted
cheers steve
indian gp -
http://www.ebay.co.uk/itm/LAMBRETTA-GP- ... 3f16641e6a
series 2 -
http://www.ebay.co.uk/itm/LAMBRETTA-LI- ... 5ae99b57de
ok compare the two ...you will see that the series 2 type (second link )is straight where the lever meets the housing where as the gp type is not ..fit the late indian type then you can fit the pm levers as i belive they do one for the nissin type m/c
^^^ They're not a straight fit tho' as the handlebars are thicker on a S2 so these would need the inside opening up to slide over the handlebar.
Steve S2
Hi
You can fit them but you have done a little griding on them
soulsurfer wrote:^^^ They're not a straight fit tho' as the handlebars are thicker on a S2 so these would need the inside opening up to slide over the handlebar.
Yes you are correct .. I had forgot about that ... Then as above you need to cut to suit
Jason Frost suggests the Vespa ones should fit, is that right, the vespa lever is the same fit as a S2?
Steve S2
Vespa levers do fit but you still have to some grinding.
smoore-gt225
hi i bought some of the scootrs atomic levers for the px vespa and they have fitted the series 2, no problems whatsoever :D
cheers steve
    Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 81 guests
