Page 1 of 3
Improving Lighting?
Posted: Sun Sep 30, 2012 10:16 pm
by servetakid
Right winter is around the corner and the nights a drawing in, I've been for a fee evening ride and I've found my Speedo light to be brighter than my headlight!!
So what can I do to improve my headlights power? I've put an LED bulb in the rear light, but what's the best halogen conversion for a lambretta out there?
Thanks
Re: Improving Lighting?
Posted: Sun Sep 30, 2012 10:35 pm
by Boothy_the_makem
Echo
Posted: Sun Sep 30, 2012 10:41 pm
by Muttley McLadd
What's your current set up?
The simplest way to make your headlight brighter than your speedo one is to remove the speedo light.
Posted: Sun Sep 30, 2012 10:48 pm
by servetakid
Haha, that's one way around it!
BGM regulator and BGM stator with a bog standard headlight set up.
Posted: Sun Sep 30, 2012 10:56 pm
by Muppet
Muttley McLadd wrote:What's your current set up?
Haha......... :lol: :lol:
Posted: Sun Sep 30, 2012 11:01 pm
by Boothy_the_makem
Snigger :bigsm:
Posted: Mon Oct 01, 2012 6:29 am
by purple_pill67
Wassell DC conversion.
Bgm led rear, led speedo bulb and get an old headlight junction box to butcher up to fit a H4 conversion block. Jobs a good un
Posted: Mon Oct 01, 2012 7:43 am
by Adam_Winstone
You lights should be perfectly good if all is well elsewhere. Providing the BGM stuff is working correctly then I'd consider fault finding other elements of the lighting system. First one to check is that you've got the tail light wired up correctly as you'll lose much of your headlight power if the wrong filament (brake light) is constantly lit when the lights are on. Could also be a poor earth, etc.
Adam
Posted: Mon Oct 01, 2012 8:21 am
by ArmandTanzarian
A knackered reflector in the headlight will lose a lot of power too.
Posted: Mon Oct 01, 2012 8:25 am
by ArmandTanzarian
purple_pill67 wrote: to fit a H4 conversion block.
Does anyone sell these ready made?
