mahle piston question
Posted: Sun Sep 30, 2012 7:45 pm
by brianc
hi,does anyone know if mahle pistons are designed not to use shims either end of the little end bearing as no matter how hard i try i cant fit them,too thght,ive assembled the top end without the shims is this ok.
Re: mahle piston question
Posted: Sun Sep 30, 2012 7:56 pm
by soosh
I don't have any on the little end on my piston.
Posted: Sun Sep 30, 2012 8:00 pm
by bazman
Posted: Sun Sep 30, 2012 8:53 pm
by DaveTomo
No shims on my mitaka piston but the crank is shimmed,but you want a bit of float anyway.If your crank is shimmed then it shouldn't be a problem,you don't want shims both ends crank and piston,either one end or the other but not both.
Posted: Sun Sep 30, 2012 9:33 pm
by soosh
Posted: Wed Oct 03, 2012 5:05 pm
by corrado
Are bike cranks shimmed at the big end?
Posted: Wed Oct 03, 2012 5:16 pm
by RICSPEED
stickies book covers this .. i think it says shims are not needed depending on the crank
Posted: Wed Oct 03, 2012 6:12 pm
by shocky
corrado wrote:Are bike cranks shimmed at the big end?
when i worked at pittville cycles we used to do alot of smaller bikes and some RD,s and they were shimmed i cant remember the smaller stuff being shimmed but all the twins were, the shims would wear on some and there were tolerance given by the makers i dont ever remember seeing any small end shims its been over 20 yrs i dont remember any cranks letting go but normally the bike would smoke and rattle which ment rings and prob crank bearing on its way out
Posted: Wed Oct 03, 2012 6:53 pm
by RICSPEED
tbh .. lambrettas are the only two stroke .. never in a four .. that i have ever worked on/had in bits that use gudgeon pin shims
Posted: Wed Oct 03, 2012 7:16 pm
by brianc
the engine is assembled and running fine,the shims are not fitted as it was impossible to fit them,il just need to see how it goes.
brian.
