Page 1 of 4
RB20
Posted: Mon Apr 20, 2009 9:40 pm
by bazman
Anyone running one and give me some feedback?
Going to build one , also will 4 plate clutch stand up to the power, and what carb 30 mm delly flatslide or mikuni 30mm (do these fit under panels?
Cheers Baz. :)
P.s notice Dan's selling kit etc , pm me if you want to do a deal for complete top end ,crank, carb etc ;)
Re: RB20
Posted: Mon Apr 20, 2009 10:07 pm
by carlos fandango
Hi Bazmzn
Im running an rb20 with a 30mm phbh, jl3, and four plate std.clutch extra stong springs.
Ive done 800 miles so far and the clutch is holding up, but recently found it slipping a little, under pressure :D so i will change to a five plate in the future.
The phbh was used because that was what i had at the time, however i now have a tmx35 but i havent got the correct jets yet so havent fitted it. :cry: The kit comes with the same manifold as the rb22 and rb25 so they are to suit the larger carb, if you want to fit a 30mm you will need a stepped rubber (you can buy a vw rubber off epay which fits, 2 for about £4 :D ).
Ive managed 78mph (gps) so far :lol:
Regards
Russell
Re: RB20
Posted: Tue Apr 21, 2009 7:52 am
by bazman
Good to hear that Russel , how do you find the engine ie smooth....powerful etc?
Cheers for the reply :)
Re: RB20
Posted: Tue Apr 21, 2009 11:27 pm
by carlos fandango
Hi Bazman
Yes it a nice ride could do with a bit more torque though :)
Missed the bit about the panels, the phbh fits under gp panels just one side rubs on the panel a little. the tmx 35mm does fit under with about 15mm clearance at the tightest point
with the phbh on its doing about 75 miles to a standard tank.
Re: RB20
Posted: Wed Apr 22, 2009 7:28 am
by bazman
Wow 75 miles to a standard tank , that's bloody good, was thinking of a bigger tank myself, i take it that's not full throttle driving though ;)
Re: RB20
Posted: Wed Apr 22, 2009 9:24 am
by carlos fandango
Not full throttle but a mix of normal driving and blasting. At full throttle would be about 50 miles. think it will be less with the tmx though
Re: RB20
Posted: Thu Apr 23, 2009 3:28 pm
by damdam
carlos what kind of gearbox are you using on your RB20 ?
Thanx
Dam
Re: RB20
Posted: Thu Apr 23, 2009 5:38 pm
by carlos fandango
Hi damdam
Ive got gp150 18/47, gaps a bit big between 3 and 4 but not two bad if you open it up :)
Tried a li150 in first 15/46 but didnt like it.going to try a gp200 when i get one.
Re: RB20
Posted: Thu Apr 23, 2009 8:40 pm
by paulmgreen
[quote="carlos fandango" if you want to fit a 30mm you will need a stepped rubber (you can buy a vw rubber off epay which fits, 2 for about £4 :D ).
Regards
Russell[/quote]
What VW rubber are you talking about here? do you have any links?
Re: RB20
Posted: Thu Apr 23, 2009 9:11 pm
by bazman
I can see your going to be busy with questions Russel so i'll ask another as well ;)
I'm building a rb 20 on gp 150 engine as well , is the gear box really bad or as you say give it some and fine !!! Notice your ratio is 4.80, maybe worth a change to around the 5.0 ?
Chers fella Baz :)
