LOSING ENGINE OIL
Posted: Thu Sep 27, 2012 3:11 pm
As you all know I have a trike derived from a 1964 Lambro Fli 175. The barrel has been uprated to 200cc (barrel stud pattern is the same), running a dellorto 30mm carb for better acceleration and a part original exhaust/silencer with an end can on it. My problem is that intermittently the engine oil is spewed out through the crankcase breather, resulting in a slipping clutch, and no further progress.
I rebuilt the engine 1800 miles ago, new crank, bearings,seals, clutch plates , in fact new everything. The engine itself runs fine. Easy to start, warms up ok, runs through all the gearing etc. The only fault is this bl:?@@dy engine oil problem.
The engine is tranverse ie the barrel points out of the side of the machine, not the front. There is no chain drive, it is driven by direct cog to cog contact inside the crankcase. The gearbox is in a little box on the back of the engine, and drives the propshaft to the rear axle. Has anyone else ever experienced this, or is it unique to my trike??
Any idea's
very welcome. I am hoping to advertise the trike for sale shortly, so would like to fix the problem. Thank you in advance.........
