south australia 1960 s2 175 stage 4
Posted: Wed Sep 26, 2012 6:41 am
by auchintibber
i bought this scooter off an old friend kat illich at last years aussie national held at fremantle.
she found it in albany i think some years back as a wreck and had it restored a few years ago by casa lambretta
australia to almost original spec.
darren lashford <rap200> pulled it apart back in adelaide only to discover the motor was horrible and badly built along with some
other mechanical and electrical faults. i will not go into everything that was wrong with it. the engine was fully stripped and rebuilt to stage 4 <darren did port tune and rebuild> front end sorted and electrics too. its taken the best part of a year to get it set up properly, but worth it.
current set up is:
sil 175 stage 4 top end, mahle 2 ring piston.
mec black crank. <li>
30mm phbh.
sil 12v stator with px pick up and low tension coil. timing set at 17 degrees. tried an agusto unit but it wouldnt run, so timing set static.
af lightened flywheel.
taffspeed mk4 pipe.
uprated clutch springs.
conti twist tyres, 100/90 rear
escort dampers and shock.
standard li150 gearing 15/46.
port timings:
exhaust 170 65% bore width
inlet 150
transfers 126
carb:
running remote filter
112 main
53 pilot
x7 needle 1st clip
av266 atomiser
ps. still running in on motul 100 mineral
starts 1st kick everytime, nice and torquey and goes very well.
sits on the road beautifully, handles and goes around corners easily!
special thanks to my mates with this, darren lashford adelaide, fenian mick perth, mark carter adelaide and adam winstone oxford.
i will post a youtube vid sometime.
Re: south australia 1960 s2 175 stage 4
Posted: Wed Sep 26, 2012 6:45 am
by Toddy
Very nice scooter mate and i suppose you have glorious weather to ride it in ;) 8-)
Posted: Wed Sep 26, 2012 6:52 am
by auchintibber
Toddy wrote:Very nice scooter mate and i suppose you have glorious weather to ride it in ;) 8-)
just started getting nice again thankyou. :fb:
Posted: Wed Sep 26, 2012 6:55 am
by Toddy
Enjoy mate :fb:
Posted: Wed Sep 26, 2012 1:41 pm
by Fenian Mick
Tis a ting of beauty Ade. How did the hills ride go?
Posted: Wed Sep 26, 2012 1:55 pm
by Adam_Winstone
Very nice :)
Posted: Thu Sep 27, 2012 6:01 am
by auchintibber
Fenian Mick wrote:Tis a ting of beauty Ade. How did the hills ride go?
it didnt, darren had problems with scoot.
i left his place and rode to the port then down coast and back home.
we are having another crack at it on monday and then next weekend is clare
valley run. :fb:
Posted: Thu Sep 27, 2012 7:37 am
by ssteam177
See you Monday morning!!
Posted: Fri Sep 28, 2012 9:01 am
by auchintibber
ssteam177 wrote:See you Monday morning!!
remind me to give you 50 beer tokens :fb:
